Thread: quick question
    quick question
    just did some overdue maintenance on my drivetrain including taking of the pulleys on my rear der. my question is if these pulleys are made to rotate in a certain direction, and if they require loctite on the bolt?
    PCC
    PCC is offline
    If they are meant to be directional then they would have an arrow showing the direction of rotation. No Loctite needed but please snug the bolts down enough that they won't fall out on their own. If you are one of those people who don't torque down nuts and bolts to spec then use the Loctite.
    Reputation: IRONMAN1518's Avatar
    Generally there is a TOP one and a BOTTOM one, the top one has more side to side play than the bottom one does. I do apply a little grease onto the bolts/bearings os they spin a little bit better. I'll use Loctite or silicone seal on the bolt threads to make darn sure they don't fall out.
    Training on Hills Builds Character, That's How I Got To Be One!
    ...idios...
    Reputation: SteveUK's Avatar
    You may find this link useful.
    Diogenes
