    Five is right out
    Question on XTR cranks, and 2 vs 3 rings
    I have't paid attention to cranks for a while so am a bit out of touch. Are XTR cranksets now fully compatible with the other Shimano cranksets or do they still differ in parts fit? I know that XTR used to use a 5 arm spider, but these days they look to be 4 arm like XT/SLX/etc.
    Second question: If I want to run a BBG bashwich with a 32T middle ring, can the arms for a 2 ring crankset be used? i.e. are the arms identical to the 3 ring sets?
    Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by womble View Post
    Thanks.
    Check the specs
    http://techdocs.shimano.com/techdocs...&bmUID=jVY9f5i
    The doubles have an 88BCD
    mtbtires.com
    Five is right out
    Quote Originally Posted by shiggy View Post
    Check the specs
    Shimano
    Yep, I remembered that site about five minutes after posting the question
    Well, XTR looks... largely compatible with XT in terms of chainrings and bottom bracket bits.
    Good to know there is a BCD difference between 2 and 3 ring setups.
    the catalan connection
    Reputation: What&son's Avatar
    Theres is a 980 crankset and a 985 crankset. The 980 has a 3 and also a 2 chainring configuration options wich use the same crankarms with std 64/104 BCD. Is the 985 that uses a specific 88 BCD and is 2 rings only (and also has a higher teeth number than the 980 double)
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
  1. 2012 XT and SLX cranks weighed w/o rings
    By lancelot in forum Singlespeed
    Last Post: 06-03-2014, 09:43 AM
  2. ss rings for m985 cranks
    By conrad in forum Singlespeed
    Last Post: 07-01-2012, 11:37 PM
  3. XO cranks with 8 spd rings?
    By kburati in forum General Discussion
    Last Post: 08-02-2011, 09:50 PM
  4. Cranks and Rings for a new 29er?
    By jtrops in forum Singlespeed
    Last Post: 05-07-2011, 06:34 AM
  5. XTR m960 cranks w/ 3 rings?
    By dirigible in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2011, 06:12 AM
