Results 1 to 9 of 9
    May 2013
    question with XT derailleur and chain compatibility
    Hello all,
    I'm thinking of switching my rear derailleur from a Sram X7 to a Shimano M786 SGS (I know I also have to change the shifter) to try and minimize my chain dropping (which at the moment is happening a lot.. already have a chainguide on the way).
    My main concern is weather or not I would have to change the chain (I have a KMC X10). This worries me because my crankset and cassette are Sram and I don't know if they would work properly using a shimano chain.
    Any help is appreciated
    Thanks everyone!
    i think sram and shimano and kmc chains are interchangeable but if the cage length on the deralieurs is different the chain length will be different
    Quote Originally Posted by natrat View Post
    Chain length do not depend on cage length.
    May 2013
    Quote Originally Posted by vanamees View Post
    Agreed, I think in this case is chain width that might be the problem
    Chains/cassettes/cranks are compatible as long as the chain matches the number of gears on the cassette.
    May 2013
    Quote Originally Posted by jlmuncie View Post
    So theoretically I could use the new derailleur and my current chain?
    really? i switched from an sg to sgs and it required another link
    Yes. No problem.
    May 2013
    Yes. No problem.
    thanks!
  1. sram x0 crank and x7 derailleur compatibility with shimano triggers and chain
    By stmarti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2014, 02:17 AM
  2. Chain compatibility question
    By backpacker0005 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2012, 12:13 PM
  3. 3x9 to 2x9 chain and derailleur question
    By curtboroff in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2011, 07:09 PM
  4. Derailleur Question - Chain Rubbing
    By runkulus in forum Beginner's Corner
    Last Post: 06-30-2011, 12:04 AM
  5. Chain compatibility question
    By jeffgre_6163 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2011, 04:54 PM
