I got my Rohloff last year , which has now around 500Km on it. Rohloff suggest a brake in period of 1000 Km ( What XTR lasted me !)
The hub is still pretty noisy in speeds 12-7-5 and I still feel a different shifting pattern between 3-4 ( and of course the usual 7-8 ) My question is : does that fade away with time? Like after 1000K + ? Should I get used to it ?
I'd like to hear from someone who has it for 5000K+......
Have you changed your oil yet? I find that after the first oil rinse & change, there is a perceptible difference in the feel of the hub.
No, gears 3 & 5 will always be noisier than the others, due to the number of planataries engaged. No escaping it. A friend I was riding with last weekend just commented on this, asking "What's that?" and commenting that it sounded like as conventional hub freewheeling.
I must say though that this "noise" varies quite a bit between the three Speedhubs in our house, and I don't find it unordinarily loud. -- just louder than the other gears, which are actually quite quiet and smooth.
I am not familiar with the 3-4 gear change you describe, and of course the real "breaking in" of the 7-8 gear change is the operator becoming familiar with it -- that'll never go away completely, just get a little smoother as you get your time in on the hub.
Yes I already changed the oil.
On mine , speed #7 is the noisier.
Between 3-4th gear , It just feels less smooth , like if there is another set going between these two , (like 7-8th going by 14th)
I've had mine since 2001, and after 4 plus seasons of racing/enduro riding, and yearly oil changes, mine is dead quite, except for when coasting, a little clicking of the ratchets inside, is about all I hear,
My newer hub (late 2003) isa little noiser but nothing to compared to a king or hadley by any means,
Just ride the hub, change the oil with a rinsing oil first when needed and enjoy problem free shifting,
Note, the dumping into 14 is better then "falling off the pedals" when trying to shift under load between gears 7 and 8
gears 5 thru 7 are(will) be the most audible as all the planerys are in mesh, well they never are out of contact with each other, it's just a matter which part of the gearset is "held" and which part is being "driven" and finally the output or "drive"
VernDogger
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
