Results 1 to 2 of 2
    Jan 2011
    Question regarding drivetrain upgrade?
    I think its time to uprade part of my drivetrain. Currently im runing a 1x8 setup with all stock components. My bike uses SRAM X4 drivetrain components...Well the rear derailleur had been damaged, and after getting it repaired twice I figured I'd just get a new one and upgrade in the process.
    I was gonna go with a 1x9 or 1x10 setup with either SRAM X7, X9, or X0 components. Not sure which untill I do a little more research.
    My question is besides the rear derailleur, shifter, and 9 or 10 speed cassettes, are there any other components essential for the upgrade? Can I stay with my stock cables? I figured there is no need to uprade the rest of the drive train. Money is tight, and I'm currently saving for a new bike.
    Thanks in advance guys
    You should replace cables, but I wouldn't worry about it too much. SRAM shifters come with cables. You may find that you want to replace housing, but again, not a huge problem, unless you are already having shifting issues.
    Since you are running a 1x setup, I wouldn't worry about your front crank, but if you switch to 2-3x in front, you will need to replace the cranks or the rings. You'll need to grab a new chain matched to the rear, but again, don't go nuts (KMC makes an inexpensive option for either, that aside from weight, works well).
Hot Deals
Contests
Latest Mountain Bike Articles
