    Reputation: carl1266's Avatar
    Question for grip shift users
    I sometimes have problems breaking and shifting (SRAM Rocket shorty) at the same time. Is it my technique or is this normal?
    Reputation: lebikerboy's Avatar
    Jan 2005
    This is normal and is one reason that rapidfire style shifters are more popular.
    Quote Originally Posted by carl1266
    Dr Gadget is IN
    Reputation: wadester's Avatar
    What technique is that?
    I normally hold the shorty shifter with thumb and pointer finger, brake lever has bad finger and ring finger. Little finger holds on tight. You can't brake and shift 3-4 gears at once - but ones&twos are okay.
    Recently switched to halfpipe (by accident - thought I was ordering shorties) and found them to work a bit better: brake with pointer/bad fingers, shift with thumb/ring finger, cling with little finger.
    On either system, unintended shifting only happens when I'm already thinking about shifting (preloaded to shift, but not yet...).
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Quote Originally Posted by wadester
    Thanks. I'll try your technique.
