Results 1 to 6 of 6
    Reputation: TrekFan's Avatar
    Apr 2005
    Question about Dual Control
    are you still able to make multiple shifts with one stroke? with the rapid fires, you could shift 2-3 gears instantly depending how much you pressed the triggers. is the same thing possible with the new dual controls?
    Old Enough to Know Better
    Quote Originally Posted by TrekFan
    Yes, but in the "faster" direction.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Only in the direction ...
    Quote Originally Posted by Grampa
    Only in the direction you're less likely to need. Like say, when you're going up a hill.
    However, when you get to the bottom of a hill and you're going 30MPH, Rapid Rise will easily allow you to select a cog 3 down so you're not forced to coast too long. And we all know how timing sensitive coasting is vs climing hills.
    BTW, Gripshifts will let you shift as many gears as you like in EITHER direction.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Yes they do. Its the same indexing mechanism as rapid fire shifters. Push the brake lever blade down and you get three shifts just like the rapid fire lever. Push it up or click the thumb button and it release one at a time. The direction it releases is dependant on the derrailleur system used.
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    Quote Originally Posted by willtsmith_nwi
    That's awesome, I hope that comes in handy sometime when you are climbing. I often wonder when I am going up a steep hill in 1 2 what it would be like to go up it in 1 9.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    willtsmith_nwi
    Jan 1970
    He .. he ...
    Quote Originally Posted by Jm.
    That was pretty funny. But where dropping the cassette comes in handy is peaking a large hill then transition into a short hill followed by another big uphill. You need to drop the cassette to pick up speed than quickly grab up those bigger gears again.
    I went BACK to grippies specifically for this reason.
  1. need your final advice on xtr dual control......
    By marco in forum Weight Weenies
    Last Post: 09-05-2005, 08:21 PM
  2. Replies: 2
    Last Post: 04-22-2005, 09:22 PM
  3. I GIVE UP! Dual Control XT 9 Speed
    By Bigfoot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2005, 02:39 PM
  4. Weak XTR Dual Control Shifter Pod Screws
    By flipnidaho in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2005, 10:43 AM
  5. Marta SL/XT rapidfire setup lighter than XTR Dual Control?
    By dawgcatching in forum Weight Weenies
    Last Post: 03-25-2004, 04:00 PM
