Results 1 to 7 of 7
    Q Factor Question
    I am currently running an LX Hollowtech II (580) crankset. It seems to have a really wide q measurement (around 175mm). Most of the other crank manufacturers don't list q (although FSA does). My question is does anyone know of triple cranks (for XC use) that have a lower q factor than the new Shimano's?
    Quote Originally Posted by allroads
    i dunno the answer to your question, but, if you use SPD pedals, you can slide your cleats all the way to the outside of your shoes. this will get your feet a handful of millimeters closer together. maybe not as much as you want/need, but hey, it's something.
    Vaginatarian
    m580= 175.4
    m960=168
    m750=167.7 with bb-un72
    m760=175
    ups and downs
    XTR 970 = 169.5mm
    If you're running Eggbeaters you can buy the narrower Q factor pedal stainless spindles now.
    Oct 2007
    Sorry but...
    What is q factor?
    Q Factor
    is the horzontal distance between the crankarms. Basically, how far apart the pedals are.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    Crank Bros Cobalt is around 167.5
    GRAVELBIKE.COM - ride everything
