    problems installing new rear der.
    Last week I broke a chain and didn't catch it before it caught the derailleur and bent it and the hanger. I bought a new XT derailleur, LX chain and a new hanger. I also replaced the cable, but not the housing. My shifters are LX shifter/brake combos and were working fine before the incident. Everything is nine speed.
    Everything is put back together but I can't get it to shift through the entire gear range and I am out of ideas. Chain length is fine. Stops are be set correctly ( I can get it to shift all the way when I pull on the cable by hand). B-stop is not set yet (though the cog doesn't hit the top sprocket when forced to shift that low). I can get the highest 3 gears to shift ok, then it deteriorates and wont even make the last two sprockets.
    I am very irritated. Ideas? Could it be something with the shifters?
    Class Clown
    Reputation: dundundata's Avatar
    did you tighten the bolt that clamps the cable while in the correct gear? ie. smallest cog with the shifter in the correct position
    I was in the correct gear when I tightened the bolt. I even tried the reverse of what you normally do and shifted all the way up and held the derailleur in place while I tightened the bolt. When done that way, I cant make it all the way to the small cog when shifting.
    Almost embarrassed to admit it, but I figured out my problem. I bought a 10sp derailleur and I have a 9sp drivetrain. Anyone need a 10sp XT rear?
  1. Having problems installing brake cable
    By corsemode in forum Brake Time
    Last Post: 08-06-2010, 11:55 AM
  2. Installing SLX crank on Pitch, having problems.
    By hitek79 in forum Specialized
    Last Post: 01-03-2010, 09:33 PM
  3. urgent problems in installing chain guide
    By jayjay05385 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2009, 10:53 AM
  4. Juicy Seven Installing Problems
    By TheTarget24 in forum Brake Time
    Last Post: 06-08-2007, 07:19 AM
  5. Problems installing FSA Pig DH
    By roee in forum Downhill - Freeride
    Last Post: 02-17-2004, 06:43 AM
