    Problems with front derailleur
    My front is giving me a lot of problems. I had the cables replaced with the front and back re-adjusted before my first ride this year. It shifted like new for the first ride. The next ride a couple of days later as soon as I got on the bike it is very noisy as the chain is dragging the inside of the front derl'r. I tried several different front and back combinations avoiding extreme angles, it won't even drop down into the smallest chain ring (which was loose!) The shifting and noise was erratic, like the derl'r was assuming different positions with the same chain rings. Once in awhile you would get a good shift, next time not.
    Did the cable relax while the bike is sitting changing the adjustment? I am going to take it back today but I am wondering if both der/'r and shifter should be replaced instead of another adjustment. They are the stock Shimano (deore?) that was installed at the factory. 3 years old.
    The first season with this bike I had no problems. last year I would have to get I adjusted every third ride or so.
    Blueliner
    Reputation: J.B. Weld's Avatar
    Most likely your cable just lost a little tension. Try turning the barrel adjuster counter-clockwise a few turns and see what happens.
    Plays with tools
    Reputation: customfab's Avatar
    Sounds like your low limit screw needs to be loosened a half turn or so.
    May 2012
    Re: Problems with front derailleur
    Is your FD tight on the seat tube?
  1. Front derailleur adjustment problems.
    By naiku in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2012, 10:22 AM
  2. 3x10 front derailleur problems...
    By Venison in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2012, 12:52 AM
  3. Sram XX front Derailleur adjustment problems on Ellsworth Truth
    By karisia_safaris in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2011, 08:50 AM
  4. Front Derailleur Problems
    By Honda Guy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2011, 05:50 AM
  5. 2009 Sultan front derailleur cable hose rubbing problems
    By Midle Age Warrior in forum Turner
    Last Post: 07-13-2011, 09:06 AM
