Results 1 to 10 of 10
    Problem removing cable from XO shifter
    I took the front plate off and instead of just being able to pull the cable out, the black disc thing is stuck to the front cover. I tried to pry it apart but it doesn't seem like that's working.
    Old man on a bike
    I don't have those shifters but that doesn't look like something in the manual http://sram.com/_media/techdocs/X0-X...ger%202-06.pdf you needed to open up.
    suum quique
    The circles go with the same color text. It is the part you need to take off, its just that the other part came off with it and I can't get them detached.
    Old man on a bike
    Gotcha. That part with the gear pry up at all? Probably want to see how it might interface with the part that came off at this point too. Do you want to experiment or warranty would be a question...
    suum quique
    I don't want to do anything that would break it. I sprayed a little wd 40 in there and pryed pretty hard, but it didn't seem like it was moving. I'm going to take it to a bike shop tomorrow and see what they say.
    Reputation: xmangox's Avatar
    solution: hammer
    =P seriously thought good luck, let us know what happens.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Did you take the center screw piece out? Its the 4 sided silver piece in the middle.
    You will need a pair of small pliers to loosen it. Then the cover comes off and then you get to fish out the cable.
    Quote Originally Posted by frdfandc
    Did you even read the thread?
    I solved the problem. I didn't realize that the screw on the outer plate was different from the one that screwed into the back. I thought it was all the same screw.
    Never trust a fart
    So I guess I was correct?
