Results 1 to 16 of 16
    Reputation: surlyjackalope's Avatar
    Mar 2011
    PressFit 30 Question
    This is probably a dumb question, but does SRAM's PressFit 30 BB work with any BB30 crankset?
    Well, given that SRAM's normal crankset requires a GXP BB I don't think its a silly question at all. I would make a guess that the BB30 bottom bracket would be different for SRAM too, but this is only an educated guess based on the fact that the method of bearing capture would be similar from SRAM GXP to BB30
    Dec 2010
    The BB30 cranks work fine with PF30 also. Its the same crankset, different bottom bracket. And the method of attachment is completely different between GXP and BB30. The BB30 stuff is much better.
    I think the OP's talking about attaching, say, a FSA or other brand crank to an XX BB
    Former Bike Wrench
    Press Fit 30 meets the same dimension and bearing standards as BB30...the only difference is that cups are press fit into the BB shell instead of the bearings directly.
    So yes, any BB30 crankset will work with the Press Fit 30 bottom bracket.
    but, is a SRAM pressfit30 BB compatible with non SRAM cranks
    Former Bike Wrench
    Quote Originally Posted by AlexRandall View Post
    As mentioned, it is compatible with ALL BB30 cranksets...BB30 is a set standard, SRAM has not altered it. Same bb width (68mm road, 73mm mtb), same inner diameter.
    Quote Originally Posted by mtnbiker72 View Post
    Sorry, not true.
    FSA bb30 cranks don't work with PressFit 30 because of different bearing preload method then SRAM's cranks.
    I don't know what's the situation with Rotor or RaceFace bb30 cranks.
    Former Bike Wrench
    Quote Originally Posted by Ojos Azules View Post
    Sorry, not true.
    The bearing preload method only applies to their GXP cranksets, their BB30 cranksets match the standards for BB30.
    Again, no.
    Here is a link where Salsa explains it:
    http://salsacycles.com/culture/build...earfish_frame/
    And here is a direct quote:
    Side Note: If you refer back to the pictures of the SRAM PFBB30, you will notice there is a
    nice dust cover, and underneath this, a seal sitting on top of the bearing. SRAM did this to
    protect the bearings, which greatly increases their useable life. Because of this detail, and
    the different pre-load adjuster FSA uses, FSA BB30 cranks do not currently play nice with SRAM PFBB30 bottom brackets.
    Mar 2011
    Ok, so it wasn't such a dumb question after all. Guess I'll stick with getting a SRAM or Shimano BB30 crankset for the PF bottom bracket.
    fai
    fai is offline
    Sep 2004
    I have been told that the FSA pressfit 30 BB will be available in September and will allow the use of any of their BB30 cranksets to be used in the pressfit frames.
    AJR
    Tá mé ar meisce.
    Reputation: BeerCan's Avatar
    Just FYI, I can confirm that Rotor BB30 cranks work fine with the PF30 BB
    To see what is right, and not to do it, is want of courage or of principle. -- Confucius
    Come join me at the Swamp
    Reputation: Hudnut's Avatar
    Apr 2005
    Sorry, not true.
    sorry, not true. that is an FSA bb30 crank with a sram pf30 bb. works fine
    FSA and PFBB30 bottom bracket (spearfish)
    Quote Originally Posted by Hudnut View Post
    You are going to let us know how long your bearings will last after your modification, right ?
    Apr 2005
    sure i'll update the modification thread. I don't see any reason they would fail prematurely. the bearings are still sealed. ask someone with phil wood mtb hubs if they have ever had bearing failure because they were too exposed.
  1. Shimano Pressfit BB
    By shirk in forum Frame Building
    Last Post: 01-31-2013, 10:04 AM
  2. Convert from Shimano to ? for PressFit
    By deuxdiesel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-01-2011, 07:22 PM
  3. Shimano xtr 970 with a pressfit bb????
    By k6monster in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2011, 11:22 PM
  4. Pressfit 30 BB Reamer
    By Clockwork Bikes in forum Frame Building
    Last Post: 02-19-2011, 10:09 PM
  5. Pressfit BB + Chainguide = ....?
    By tomas101 in forum All Mountain
    Last Post: 03-23-2010, 09:41 AM
