Results 1 to 3 of 3
    Reputation: mizzaboom's Avatar
    Jun 2010
    Press fit vs. X-type BB
    I just picked up a new 2011 Trance x1...super stoked on the purchase, got a great deal from the LBS.
    I was previously running the SLX crank/x-type BB on my old hardtail. The Trance comes with the Deore XT crank/press fit BB. It is my understanding that XT is "better" (higher in the Shimano line) than SLX. However, I was also under the impression that the x-type BBs were the way to go. Probably a question I should have asked at the LBS but I was so excited after my test ride that the question faded from the front of my brain.
    Basically - what is the difference?
    Thanks in advance!
    On the Shimano setup, my understanding is that the only difference is no threads on the bearing cups/carriers. Almost exactly the same otherwise. You could swap your cranks between the bikes and they would work fine.
    Jun 2010
    Thanks, Slash. That helps a lot. Good to know I have solid back up in the SLX that is compatible!
  1. Replies: 3
    Last Post: 07-28-2012, 05:36 PM
  2. BB92 Press fit BB: How much "press"ure?
    By Entrenador in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2012, 07:54 PM
  3. more ij press.
    By btheb in forum California - Norcal
    Last Post: 11-15-2011, 02:03 PM
  4. press fit bb on hd
    By spooney in forum Ibis
    Last Post: 07-31-2011, 12:47 AM
  5. Shimano press fit BB92 and GXP press fit BB92 the same?
    By Stryder75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 04:28 PM
