Results 1 to 6 of 6
    play in cassette?
    should a cassette have a little play in it while on the hub? If i am facing the side of the wheel and grab the cassette with both hands at 3 and 9 o'clock, if I pull with one hand and push with the other there is a little bit play, about 1-2 mm. Is this normal? I've never checked this before; my bike was making a little rattling sound at speed so i was trying to find something loose. Could have been my imagination though. could this be why? it's a new sram pg-970 9-speed on a 2005 mavic crossmax xl wheel. Thanks.
    Meh.
    Reputation: XSL_WiLL's Avatar
    No. If it's play in the cassette, you may need a spacer behind the cassette.
    Is it possible that it's play in the freewheel? or the hub itself?
    I had the same problem. There was play with a new cassette, and play disappeared reinstalling the old one.. It's difficult to explain , but if you are replacing the cassette try to re-use the old 11t cog and see if the play still exists.
    fab
    Reputation: FireDog46's Avatar
    from Sheldon Brown
    http://sheldonbrown.com/harris/k7.html#11
    michael
    "Be not afraid of going slowly but only of standing still." - Chinese Proverb
    Quote Originally Posted by FireDog46
    that's exactly what I was trying to explain .. but in appropriate English!
    I have a Mavic Crossmax XL 2005.
    After about 6500 km I noticed about the same amount of play. I tried several cassettes and all were the same.
    Turned out to be a worn freehub, So I got another freehub ($64.00), and the play is now very minimal. I am not sure the play really affected anything though.
    There is a rub ring inside the hub that just wears out.
  1. Slight play in XT cassette
    By misctwo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-15-2006, 05:30 PM
  2. Play in freewheel/cassette
    By Megaclocker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-24-2006, 09:53 PM
  3. Play in cassette
    By Fast Eddy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-17-2005, 10:11 AM
  4. Play in a cassette?
    By juswalk in forum Wheels and Tires
    Last Post: 04-01-2005, 08:20 AM
  5. play in LX cassette?
    By JustScott in forum General Discussion
    Last Post: 06-14-2004, 08:07 AM
