Results 1 to 3 of 3
    Reputation: 02_NRS's Avatar
    "plate" on left xt/XTR 760 crankarm???
    part # y1fu98120 installs in the gap w/2 bolts passing thru.seems to fill the gap on the non drive arm but when I looked at one on a new bike the gap did not close enough to contact this PLATE! is it in the www.shimano.com tech drawing only?also anyone else have the 2 'O' rings on the center plastic tube ends?
    Mine has the little plate installed, I think it helps keep dirt out.
    I have 1 o-ring on each end of the center tube. Part no 15.
    Part no 13 are shims that go between the bearing cups and the frame.
    BTW I always forget to put the center tube in, I have never seen any dirt or water in my BB so next time I forget, I think I will leave it out.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    mine doesn't have that plate.. and mine cranks are about 3 years old... weird.. never seen it before..
    why would it have a '*' next to it in the item number?
