Results 1 to 8 of 8
Thread: Pedal removal?
    Florida Rider
    Reputation: atomrcrkhsbiker's Avatar
    Pedal removal?
    Do I need any special tools for removing my pedals? and how do I remove them?
    The devil is an angel too
    Mar 2005
    Here is a link that should answer all your questions:
    http://www.parktool.com/repair/readhowto.asp?id=83
    Reputation: gmats's Avatar
    Apr 2005
    Some of them use 15mm wrench. Some require a thin 15 mm wrench. Some can be done with a 8mm allen wrench.
    Right side pedal is standard thread. Righty-tighty Lefty-loosey.
    Left side pedal is left hand (reversed) thread. This means "Righty-loosey" "Lefty-Tighty"
    Hope that helps.
    Reputation: logbiter's Avatar
    Quote Originally Posted by gmats
    Hope that helps.
    Right on gmats!
    I just wanted to add that the allen wrench would be used on the backside of the arm, if that's not immediately obvious.
    AND
    Be sure to use some anti-seize on the threads when reinstalling! (or some grease)
    Reputation: standard235's Avatar
    Go grease not anti seize.
    Florida Rider
    ok, cool thanks
    Remember backwards is forward
    Remember if you are using the allen wrench on the inside of the pedal; the direction is oppisite as if you were using the wrench
    Quote Originally Posted by Gilboy
    to remove pedals, i usually just have the wrench handle pointing up and turn towards the chainstay, not really sure which side is reverse thread.
