Thread: Pedal help
    Tenya Laybacker
    Pedal help
    I am looking for a new pedal system. I have only used the SPD system and am interested in some of the other systems. I have found that the SPD clog up pretty quick and that I start to have difficulty releasing in technical terrain. I have crashed because I could not get out fast enough in steep ,wet and slippery rocks and logs. What pedal system do you think is the easiest to get in and out of in a hurry? Time ATAC XS or Eggbeaters? Others? Thanks for your help.
    I know I'm stating the obvious, but are you prepared to consider some decent pinned platform pedals? Zero problems getting off them when you need to, but some folks prefer to be clipped in.
    Eggbeaters!
    I got a set of Cook Brother's Candy SL pedals this spring. I like them a lot. I've had Ritchey and Shimano clipless pedals in the past. I like the Candys over any other pedal I've had. They are relatively light. Durable - I ride quite a bit of technical terrain with roots and rocks so they take some hits against rocks once in a while. They have stood up nicely so far. Also, I like the no spring tension adjustment necessary. Just put them on your bike, mount up the cleats (may take an adjustment or two) and your good to go. Preset spring tension is just right. I'm able to quickly clip out in desparate bail situations. I don't ride a lot in the mud, but the times I have, they have performed well.
    I recommed the Candies, or the straight up Eggbeaters if you don't need the platforms.
    And there's a good reason we prefer to be clipped in. :-)
  1. Do pedal cleats really wear out? (OT)
    By aka brad in forum Singlespeed
    Last Post: 08-14-2004, 09:45 AM
  2. 575 pedal strike?
    By jpre in forum Yeti
    Last Post: 07-30-2004, 09:20 AM
  3. How is this bike going to be
    By RedDwarf in forum Downhill - Freeride
    Last Post: 06-12-2004, 09:49 PM
  4. Removing pedal inserts...
    By namaSSte in forum Downhill - Freeride
    Last Post: 04-20-2004, 01:52 PM
  5. how noticable is pedal weight?
    By dumper in forum General Discussion
    Last Post: 02-29-2004, 08:03 AM
