Thread: PC991 hollowpin
    Reputation: Havoc138's Avatar
    PC991 hollowpin
    is there a special chain tool needed to remove the pins? or some sort of adapter that fits a standard chain breaker?
    Reputation: Mullos's Avatar
    Jun 2005
    Quote Originally Posted by Havoc138
    Check out the Sram website as they have Technical manuals in PDF you can download.
    Cheers and good luck.
    Singletrack Addict!!!
    Reputation: Relayden's Avatar
    Jun 2005
    I use regular chain breakers to cut to lengh and then everything else is done with the power link, if you manage to break one, only use a new powerlink, do not add a link of the ones removed as the pin will not hold and snap again. Granted powerlinks are quite expensive $4, but if you break a chain on the road, it only takes about a minute to replace.
    The world needs a huge socio-economic change...be it. We all need to ride more....
    Quote Originally Posted by Relayden
    thank you for the reply. for some reason my Park chain tool pin doesn't fit the hollow pins. maybe other brands do
