Results 1 to 7 of 7
    Bicyclochondriac.
    Oversized (36t-38t) 9 speed cogs with wide base (Al carrier friendly)?
    I have been toying with the idea of modifying my 9 speed cassette by adding a single oversized cog. Something in the 36t-38t range. My concern is that I have an aluminum cassette carrier, and a typical single cog (as opposed to cogs on a carrier) of that size is going to dig into the carrier pretty good. I've leaned this the hard way with a loose 32t cog, and I assume a larger cog will only be worse.
    What I am looking for is a single cog that has a wide base, like some Single Speed cogs I have seen. They flare out and get thicker where they interface with the carrier. Anybody know of one?
    If I were running 9 speed I'd be looking at the General Lee Wide Range adaptor, but it looks like it only comes in 10 speed. Might be too much $ though.
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Quote Originally Posted by kapusta View Post
    Why not use the Shimano 12-36 9 speed, isn't that 36 spider/unit a couple cogs wide?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Deerhill View Post
    No. The 12-36 9-sp is individual cogs.
    mtbtires.com
    Reputation: Nater's Avatar
    There is this one from MTB Tools on eBay.
    36 Tooth Cog for Mountain Bike Cassette 36T Sprocket | eBay
    Otherwise, what hub are you running? Maybe there is a steel freehub body available for your hub that would allow you to use the Shimano 12-36 tooh 9 speed cassette.
    Hope and King for instance offer steel freehub bodies.
    Bicyclochondriac.
    Quote Originally Posted by Nater View Post
    I did see that one, but it does not look to me like it gets thicker at the base. I asked the seller just in case.
    I have a hope pro 2 hub, the first generation. I have considered looking into a steel body, but again that is getting into more $ than I would like to spend.
    EDIT: Just heard back from the seller it is a uniform thickness, NOT flared at the bottom.
    moar alike..
    Dec 2009
    Quote Originally Posted by shiggy View Post
    Luckily This thread is here, was about to pick one up for my ss.. thanks shiggy.. You seen if the 10 speeders have a sprocket unit there? May have to mod one of those
    Mar 2011
    someone used to make an adapter to mount 4 bolt chainrings onto a shimano freehub. this was a few years back and i couldn't find it via google search so they might not be around anymore.
  1. Buying individual cogs for an Sram PG 990 9 Speed Cassette
    By KVW in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2014, 12:17 PM
  2. Single Speed friendly trails around PDX
    By Bike Whisperer in forum Oregon
    Last Post: 10-23-2012, 09:25 AM
  3. Source for individual (9 speed) XT cogs?
    By chucko58 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2012, 05:37 PM
  4. Some Ideas for Wide Tubeless Friendly 26er rim brake Rim?
    By Metamorphic in forum Wheels and Tires
    Last Post: 12-20-2011, 10:49 AM
  5. SRAM 10 speed cassette cogs
    By tigoat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-18-2011, 08:26 AM
