Results 1 to 10 of 10
    In my mind, I can do it!
    Reputation: iviguy's Avatar
    One more time on shifter wiring..
    I posted on this problem before and since then have learned more about it but also caused more questions. I have a new shifter for my old bike but there doesn't appear to be any place to run the shifting wire. No holes, no plugs, nothing. I can't figure out how the wire is supposed to be threaded through the shifter. I took a lot of pictures so maybe someone can tell something.
    Quote Originally Posted by iviguy
    Rest of the pics:
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    There should be a small plastic type screw on the opposite side of where the gear cable comes out of that you might have to remove to get to the cable. Also the cable won't come out if you don't have it in the lowest gear(1 in the front, 8 in the back).
    Quote Originally Posted by mtb_biker
    I didn't see any plastic screw or any plug on the opposite of where the cable comes out. Do you see it in one of the pictures?
    -> SickLines.com <-
    I dont' see it in any of the pictures (not sure if theres one missing or what. The easy way to find out where its supposed to come out is to again put it in the lowest gear (1Front) then gently move the cable in/out until you hear it hitting the side of the shifter. This is where it comes out at. It might be that the lx 8speed might need to have one of those pannels removed to get it out.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    I would guess you need ti remove the bottommost plastic panel.
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    Try this
    Here are some diagrams from the Shimano web site:
    LX Shifter exploded:
    http://bike.shimano.com/media/cyclin...9830539745.pdf
    LX Dual Control Lever exploded:
    http://bike.shimano.com/media/cyclin...9830539731.pdf
    if you have the shifter only, you're looking for #3, "Inner Hole Cap"
    I can't quite tell what it is on the shifter/lever combo, but i think it's #9, Release lever fixing bolt.
    I had a difficult toime finding it on my XT shifter/brake lever combo, but it's definitely there.
    Clyde
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Quote Originally Posted by Hecubus
    I think that is about the only option I have. There is definately no screw or cap covering a hole for the cable to slide through. I hate to remove that cover because I don't know what may pop out. I have ruined a couple of shifters trying to take the bottom cap off before. Oh well, it ain't no good to me without a cable. If I break it, I suppose I will have myself the makings of a single speed.
    Chrome Toaster
    Quote Originally Posted by Call_me_Clyde
    Clyde
    Its not the same version. Those schematics are for the 570 9 speed shifters. These are old 8 speed LX shifters.
    Chrome Toaster
    I doubt you'll ruin it. That bottom cap with the phillips screw right in the middle looks like it was designed to be easily taken off for no other puspose.
  1. Replies: 66
    Last Post: 06-26-2014, 01:20 PM
  2. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  3. CCP Stories
    By General Coonskins in forum Singlespeed
    Last Post: 06-30-2004, 10:03 AM
