    Nov 2008
    Is it ok to use a 9spd link on a 10spd chain?
    I accidentally broke the master link (a.k.a reusable missing link) on my 10psd KNC x-10 chain. Since I only had a SRAM 9spd replacement link, i used that to connect the chain. I rode 30 Km without any issue, but is it a good idea to leave the 9spd link in place, or should i replace it with a dedicated 10spd link?
    Reputation: mitzikatzi's Avatar
    No replace it with a proper 10spd quick link.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Nov 2008
    You should go grab a few of the 10 speed masterlinks, not the best idea to use a 9spd since its wider. With that said....If you were stranded out in the middle of nowhere and only had the 9spd link...then by all means use it as a last resort. Just not worth the potential riskif you can easily access the 10spd links.
    Mar 2011
    it will work as a stop gap the internal plate spacing is the same 9 or 10 speed - A mate bust his 10 speed chain a couple of weeks ago and we couldn't get the pin back in properly with a crappy multi tool chain breaker so I ended up putting my spare 9 speed SRAM power link in for him - it got him home fine and better than riding with a stuck link- it is noticeably wider than the chain though.
  1. New 9spd 2012 RH -->10spd
    By millertm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2013, 05:08 AM
  2. 9spd RD with 10spd shifters
    By LyNx in forum General Discussion
    Last Post: 05-02-2012, 08:36 PM
  3. Lemme get this straight: 9spd to 10spd
    By PaintPeelinPbody in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2012, 08:10 PM
  4. 10spd is 9spd
    By Strike the primer in forum Banshee Bikes
    Last Post: 02-22-2011, 09:40 AM
  5. HALF link link needed ,using 9spd sram geared chain
    By zippy895 in forum Singlespeed
    Last Post: 02-05-2011, 08:25 PM
