Results 1 to 9 of 9
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Offsetting chainrings outwards
    Hello,
    On my new bike build, I was plan inv on running 24-38 chainrings on a triple crankset. I don't have the rings yet but whn installing my triple I wondered if a 38T would clear the frame. After checking with the frame builder it turns out it wouldn't. I need to have a 50mm chainline double for a 38T to clear the frame.
    So I've looked up my options. Given the BB shell is 73mm, I cannot simply move a spa er to the drive side. I think adding a spacer could work but I don't remember seeing anybody do this. I also thought of using offset chainrings but can't find any with a big enough offset to compensate the chainline as required. Does any exist?
    Any other option for me out there?
    Check out my SportTracks plugins for some training aid software.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Which cranks and BB are you using? Chances are you could switch to a longer spindle, which would widen your Q-factor a bit, but also move both rings outwards.
    g3h6o3
    Oct 2007
    Shimano XT 775 so that is not an option
    How much do you need? I've been running extra spacers on one of my single speeds for a better chain line without problems. Just can't use the plastic stopper thing on the non-drive side - it won't drop into the hole. The thin spacers for freehubs fit bottom brackets.
    g3h6o3
    Oct 2007
    I need around 2.5mm to 3mm, basically a BB spacer.
    The "plastic stopper thingy" you speak of is the hook that prevents the crank from puling out, right?
    Correct. Without it, if the arm comes loose, it can fall off. I've had no problems running with an extra spacer. Give it a try and see how it looks.
    Bicyclochondriac.
    Quote Originally Posted by PissedOffCil View Post
    Hello,
    If it turns out you can't accommodate the 38t ring easily, have you looked that the difference in gear ratios dropping down to a 36t? It is pretty small difference (about 5%, or half a typical gear change).
    g3h6o3
    Oct 2007
    I've been told a 36 would probably not work either... I really need to keep the 50mm chain line to clear the frame.
    Thx everyone
    Happy Trails
    Reputation: Scott In MD's Avatar
    FSA has a brand new line of rings made specifically to convert 3x9 to 2x10. The are called D-10 rings, and are offset. Also have nifty caps to fill the space on the spline where the big ring used to be. You can find an articles e on BikeRumor or email Chad at FSA for info.
  1. Why 10-speed chainrings sell at much higher than 9-speed chainrings
    By solitone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2014, 04:49 PM
  2. Replies: 1
    Last Post: 10-08-2012, 01:26 PM
  3. where to get fsa sl k 386 chainrings
    By dang in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2012, 08:26 AM
  4. Chainrings...
    By CBRsteve in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2012, 06:13 PM
  5. need new chainrings
    By mission2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2012, 08:13 AM
