Results 1 to 2 of 2
    Oct 2007
    Nomad + stylo + boxguide = ?
    i am changing my sc nomad to single ring up front with chainguide.
    bought a bb truvativ box guide and 36t chainring, plus new chain,cassette and der.
    i had intended to use to stock truvativ stylo gxp crankset that came with the bike(2008),but the lugs that the granny gear usually attaches to are hitting the bolts on the boxguide.
    do i need another crank?
    can i just grind them lugs away?
    cheers.
    Aug 2005
    I bet your bolts have rounded heads? If so you try to find bolts that have flat heads like what was shipped with older e.13 stuff. If you never want to run a granny again I see no reason not to grind them off .
