Results 1 to 3 of 3
    Reputation: KRob's Avatar
    Newer M752 XT Crank= different chainline?
    I just replaced my XT cranks with a newer model M752 Hollowtech XT Crank and now my front derailleur rubs the chain when on the big ring. If I move it over any more, then it won't shift down onto the granny. I didn't have this problem on the old crank... should there be a difference here? Shouldn't I be able to find a happy medium? I'm still running the same Octalink BB. This is not the newest integrated BB/crank, outboard bearing version.
    Old man on a bike
    You're maxed out using the low and high limit screws?
    suum quique
    Quote Originally Posted by Bikinfoolferlife
    The high limit screw is maxed out (I think....not touching the derailleur at all?) but I was thinking about this when I was spinning on the trainer this morning. Maybe if I pull a little more cable through so the chain clears the deraileur, then check the granny ring stop adjusment screw to see if I can gain anthing there. I forgot to do that the first time I fiddled with it.
