Results 1 to 7 of 7
    Dec 2005
    Newbie Q on changing shifters
    I have an 05 Specialized Epic Disc which has,
    front deraileur: Shimano LX
    rear deraileur: Shimano XT
    disc brakes: Avid mechanical cable
    shifters: Shimano LX
    Brake levers: Avid
    My only gripe is that I have a smallish hand and short thumb. I find that chaging to the highest gear on front, or lowest on rear to be hit and miss affair. I often do not push with my thumb hard / far enough.
    For above reason, amongst others, I have a desire to upgrde the shifters and really like the idea of Shimano's dual control. I am assuming one of the Shimano XT or XTR
    would be ideal. The question is;
    -Which model exactly should I start shopping for - that will work with all
    my other components? I would probably stay with XT/XTR for the bling factor.
    Reputation: shiggy's Avatar
    Dec 1998
    First go test ride some bikes with dual control levers to see if they work for you.
    You will be looking at $200-300 for the levers alone.
    mtbtires.com
    Reputation: flipnidaho's Avatar
    What Shiggy said... Plus..
    I have Dual Control XTR and the brake/shifter levers have a relatively small range of adjustment to get it closer to the bar. You may also want to consider SRAM Grip Shifters (lighter as well).
    PCC
    PCC is offline
    Try rotating them around so that the thumb paddle sits higher.
    Dec 2005
    Thanks for your replies...
    1. I will testride a bike with it first.
    2. I have a (unrealistic as it may be) dislike for grip shifters.
    3. I have moved it one way and another around the bars - still have difficulty getting shifts into Large cogs.
    One more question please... I've been reading that the Dual Controls are ideally used with Low Normal rear deraileur. I have the "normal" XT rear Deraileur - would they still work together?
    Am I correct to say (with my "normal rear deraileur);
    Front - Push Down to change to higher gear (larger ring)
    Rear - Push Down to change to Lower gear (larger cog) ??
    PCC
    PCC is offline
    My bike came originally with a high-normal rear derailleur and Deore shifters. It worked great. I converted it to a low-normal rear derailleur and it worked great.
    With a high-normal rear derailleur, shifting is like you described.
    Quote Originally Posted by shiggy
    Actually for less. A set of XT dual control levers for V-brake/Cable disc brakes can be had on ebay for about $100-130 or purchased from Nasbar for $143.10 after a 10% coupon. If you don't mind LX levers- Nashbar has them for $76.76 after 10% coupon.
    I bike; therefore, I work
