Results 1 to 14 of 14
    Riding free's the mind
    New SRAM XO Shifter/derailleur
    Have any of you seen the ad for the new SRAM XO trigger shifter and XO Blackbox technology rear derailleur? Is this available now?
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Its already showing on Srams site. Its not available yet though. My guess would be that it will be released at some point late this year most likely around Interbike.
    Quote Originally Posted by HTail
    ETA June 1st!
    http://www.mtbr.com/spotlight/srammediacamp/
    Competition
    Those of you with SRAM experience.....
    Do you have to run a SRAM cassette to use their derailleurs?
    Do you have to use a SRAM chain?
    This is the first time I'm actually considering changing from Shimano XTR.
    Reputation: Angel Crusher's Avatar
    SRAM Drivetrain
    You can mix and match componets to some extent. Obviously you can use a XT/XTR rear with SRAM 1:1 shifters, you can use a shimano cassette and/or chain. I run an X.9 drivetrain with X-Gen front, but I use an XT cassette. Everything works great and the shifting is far superior to the old XT/XTR setup I had before.
    NoTubes.com
    Quote Originally Posted by Angel Crusher
    A slight correction to Angel Crusher's post - with a Shimano rear you need to run the SRAM 2:1 shifters. The easy way to tell is the 1:1 shifters are numbered, X.0, X.9, X.7, etc and the 2:1 (Shimano compatible) shifters are named, Rocket, Attack, etc. You can mix up the drivetrain beyond that to your hearts content.
    Please do not use the forum PM or e-mail function for business related questions. I can be contacted through our website. Thanks!
    NoTubes.com
    Actually how about this situation...
    So what if I have the following setup:
    - Shimano XTR 9 speed cassette
    - SRAM XO rear derailleur
    - SRAM XO trigger shifters
    - Shimano XTR front derailleur
    Will these work together?
    The Riddler
    Reputation: Kaparzo's Avatar
    yep.
    my setup is
    XO rd, and shifters
    XT casette, much cheaper, more durable, and not that much heavier than xtr
    xt front der.
    sram pc99 chain
    Meh.
    Reputation: XSL_WiLL's Avatar
    It'll work fine. Sram front derailleurs are still 2:1 actuation ratio. Rear derailleurs are 1:1. I'm using a SRAM cassette and PC 69 chain with Shimano Deore/XT derailleurs and Truvativ cranks.
    Mar 2005
    Forgive me for being confused, I was under the impression that all front derailleurs were 1:1... I had a mechanic tell me this too but I wouldn't be suprised if this was wrong.
    Seems to me that SRAM is actively getting into the thing you hated most about Shimano....planned obsolecence. :-)
    Meh.
    Nope, all front derailleurs, and Shimano derailleurs are 2:1. Only the SRAM X-Gen Rear derailleurs are 1:1.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    That is ...
    Quote Originally Posted by Mike B.
    That is unless it's Rapid Rise. Than Attack and Rocket shifters will work backwards. You'll only be able to downshift one cog at a time, just like XTR ;-)
    willtsmith_nwi
    Jan 1970
    Actuation Ratio ...
    Prefer putting the horse before the cart. The cable controls the derailleur, not the other way around. It's 1:2 actuation (though, I've seen it used both ways).
    For example:
    1 mm cable pull : 2 mm derailleur movement
    .5 mm cable slop : 1 mm derailleur slop
  1. Replacement SRAM XO parts... (Where can I get etc?)
    By Trevor! in forum Weight Weenies
    Last Post: 05-28-2004, 08:28 PM
  2. SRAM X.9 shifter/ XO R. Der. vs Shimano
    By Manny Omega in forum SRAM
    Last Post: 04-15-2004, 01:39 AM
  3. Replies: 4
    Last Post: 04-12-2004, 07:40 AM
  4. sram xo or xtr shifting?.........
    By marco in forum Weight Weenies
    Last Post: 03-15-2004, 02:37 AM
