Results 1 to 3 of 3
    Mar 2006
    New Frame bottom bracket?
    How important is it to have the bottom bracket shell chased and faced before installing a new bb?
    If the frame is new and never been faced it is very important. If you are replacing a BB then it should be fine
    Depends, on highend frames usually this is all done
    Quote Originally Posted by Downeaster
    If i see paint anywhere around or in the headtube/bottom bracket I usually get things faced but since i can't get it done for free (used to work in a sporting goods store) anymore i have been known to clean the paint out with a razor blade and "chase" the threads with a steel BB. But Yeti frames definitely do not need to be done, check out the Tour, click on "Frame Prep".
