    Professional Nerd
    Reputation: Danimal's Avatar
    New barrel adjuster...
    My barrel adjuster for my rear derailleur was bent in shipping. The black plastic peice on the outside is fine, the actual metal adjuster inside of it is bent pretty badly. Obviously this causes erratic shifting (as the cable also has a kink in it) and the occasional chain skip.
    I have a Deore 9sp rear derailleur, does anyone know where I can get this piece?
    -Danimal
    Try...
    Quote Originally Posted by Danimal
    -Danimal
    your local bike shop. You'd be surprised what they have laying about. Of course you'll check the threaded portion before getting just the barrel right?
    Professional Nerd
    Quote Originally Posted by fred3
    Indeed, I will check the LBS.
    I'm not sure what you mean...the threaded portion is what is dammaged, the black plasic barrel on the outside is fine.
    Sorry if my description was confusing!
    Thanks for the reply
    -Danimal
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Definately take a look at your local bike shop. They should have those miscellaneous parts left over or broken derailleurs they butcher for little parts like that. You can also order the barrel adjuster through the QBP catalogue from the bike shop or even online.
  1. XTR rear barrel adjuster
    By jspharmd in forum Beginner's Corner
    Last Post: 02-25-2005, 11:13 AM
  2. Pike compression adjuster mod
    By scrublover in forum Shocks and Suspension
    Last Post: 12-21-2004, 12:05 PM
  3. Lefty sans compression adjuster?
    By SpinWheelz in forum Cannondale
    Last Post: 10-13-2004, 10:34 PM
  4. Won't shift to one gear, please help!
    By Lucky13 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2004, 05:51 AM
  5. help
    By the Inbred in forum Singlespeed
    Last Post: 02-19-2004, 11:25 AM
