Results 1 to 7 of 7
    New 8 speed cassette
    So I bought a 2010 Motobecane 600 HT a couple months ago. I came to learn that it comes with what I think is a cruddy cassette for my climbing purposes. It's a 12-28t (SRAM?) powerglide, and I've noticed when climbing that both my friends pedal much more in their lowest gears to cover the same distance, and I want that lower gear ratio. I want an 11-32t cassette replacement, but I am not going to spend the kind of money required for an XTR cassette if you know what I mean. I need a good budget 11-32t cassette. Any suggestions?
    Edit: part of the reason for getting the new bike was to get an additional gear on the back end for climbing purposes, one more than my 7 speed rigid frame. However, the 7 speed has 28 teeth in the lowest gear also, so this doesn't do me tons of good. That's why I need a different cassette.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    You can get a SRAM pg 850 for a cheap price for no more then $35.
    Former Bike Wrench
    I recommend Shimano HG 40...the 11-32 has less of a jump from the 1-2 gear than the SRAM
    http://www.universalcycles.com/shopp...11&category=42
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    Two biggest choices will be SRAM and Shimano. Sram 850 comes in a 11-32. Shimano HG 70 comes with an 11-30.
    If you can find one Sunrace has a 11 or 12-34 too. Model CSM66.
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
    I've been using 11-32 Sram 850's for years. I usually pay between 15 and 20 dollars for them on sale.
    Thanks everyone for your input! I was considering the Shimano hg series because of the 28-32 transition from 2nd to 1st gear instead of the 26-32 in the SRAM. I looked at both the hg40 and hg50. Which is better between the two? I have heard tons of good things about the SRAM pg850, but also that they don't last as long as the shimano. Amazon is selling the hg50 for $20 free shipping right now.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by akamarcus View Post
    Pick the one with the ratios you want. The function is about the same.
    mtbtires.com
  1. 9 speed derailleur compatible with 8 speed cassette/shifter
    By wensiaw@pacific.net.sg in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2014, 05:06 AM
  2. 10 speed / 9 speed cassette range comparisons
    By TigWorld in forum Weight Weenies
    Last Post: 04-11-2011, 02:53 PM
  3. Does 9 speed shifter like deore able to work on 8 speed cassette?
    By shimano4 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-27-2008, 02:51 PM
  4. New 9-speed cassette replacing a 7-speed...compatable?
    By SkizitJNM in forum Beginner's Corner
    Last Post: 05-25-2007, 11:47 AM
  5. 8 speed chain, cassette with 9 speed shifter derailleur?
    By edmoloco in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2006, 11:18 PM
