Results 1 to 3 of 3
    Reputation: progfan1's Avatar
    New to 2x10: wear questions
    Hello,
    I just checked my chain wear and it's borderline, according to the gauge. I have zero problems with slippage right now. I also was just getting the bike checked out at the shop for other things and they guy said my cassette was a bit worn. Again, I have had zero slippage problems. I have probably just under 1000 miles on them. I am new to 2x10 and have been climbing in harder gears than I used to, so no doubt this is contributing some to the wear. If I switch out the chain now, do I absolutely need to switch the cassette? Should I just switch the chain and wait until I have slippage issues to switch the cassette? I know some people say you absolutely have to switch both at the same time. There are currently no "shark teeth" on the cassette. Any advice would be greatly appreciated.
    2012 Salsa Horsethief
    2005 Independent Fabrication Deluxe
    Reputation: thickfog's Avatar
    Oct 2010
    Re: New to 2x10: wear questions
    Many chain guage wear tools are not so accurate. Use a ruler. Try giving this a read: http://pardo.net/bike/pic/fail-004/000.html
    Also it's perfectly fine to replace a chain but not the cassette. Usually not the other way around though.
    Sent from my SCH-I535 using Tapatalk 4 Beta
    CRAMBA Chairman
    Reputation: reamer41's Avatar
    If you do have slippage it's time to replace the chain, cassette, and chainrings. Big bucks!!
    If you replace your chain (well) before it is so worn that you have 'slippage' and shark teeth than all you have to replace is the chain for just the cost of the chain.
    You can drastically increase the life of your cassette an chainrings by replacing your chain before it is totally worn out.
    I've learned the hard way. Twice.
    --Reamer
  1. 2x10 conversion questions
    By tigris99 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-15-2013, 11:41 AM
  2. Replies: 9
    Last Post: 04-03-2012, 10:56 AM
  3. FSR Bolt Kit and wear questions
    By csf in forum Specialized
    Last Post: 02-01-2012, 11:25 AM
  4. 2x10 to 3x10 Questions
    By BaeckerX1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2011, 05:52 PM
  5. x0 2x10 on HL spot questions
    By jh_on_the_cape in forum Turner
    Last Post: 04-04-2011, 06:45 PM
