Results 1 to 12 of 12
    May 2013
    Need RD suggestion (Altus broke)
    I somehow got my RD caught up in my spokes on my Diamondback Response, bending the hanger and the sprocket plate coming off the derailleur.
    It seems like I might as well spend a couple of extra bucks and get an upgraded RD. The bike has a 7-speed freewheel rear hub. I was thinking I'll get a Deore of some kind, but there are SO many options out there. I looked around on BikesDirect and saw that some of their lower-level Deore-equipped bikes use the M591.
    So is the M591 a good replacement RD? They're about 40 bucks on eBay. Should I be looking at anything else?
    Also, will I need any other parts? Will my existing shifter work OK?
    Reputation: millertm's Avatar
    Just make sure that it is a 7spd, I'm not sure if 8spd will work and I am sure the 9-10spd will not work. If you can, look at an eight speed upgrade. If not, the Deore will be fine.
    Mark
    2012 XXL Carve Expert
    Reputation: mitzikatzi's Avatar
    9 speed will work.
    10 speed will not work.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    I stand corrected, thanks Mitz.
    Mark
    May 2013
    Quote Originally Posted by mitzikatzi View Post
    9 speed will work.
    So the M591 will work?
    To add another wrinkle, I now have integrated shifter/brake levers. I'm upgrading to hydraulic brakes. I'll need to get new shifters. Does it make sense to get a SRAM RD if I get SRAM 3x7 shifters or does it not matter?
    May 2013
    Any other comments? Thanks again.
    Oct 2011
    You can go with SRAM X3 3x7 shifters and SRAM X3 7-speed rear derailleur. Very cheap but solid stuff. You don't need to change your front derailleur. Which hydraulic brakes are you going to get?
    May 2013
    M596 brakes. Would there be some advantage to using SRAM instead?
    Looks like my options for 3x7 shifters are X3 or Acera. Price is about the same. For the RD I can do Deore or SRAM x3/5/7. I'm inclined to go Deore and Acera because I can get those on Amazon Prime.
    Would that work? The M591 RD with Acera M310 shifters? Or would the x3 combo be better?
    May 2013
    Here's what I'm looking at:
    Shimano setup:
    RD-M591 Deore RD $47
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    SL-M310 Acera shifters $14/each
    Shimano Acera SL-M310 Rapid Fire Shifter, Right (Black, 7-Speed) : Amazon.com : Sports & Outdoors
    Looks like I'm stuck at the Acera/X3 level with my 7-speed rear hub. I could do the X3 shifters and X3/4/5 RD if there's a good reason, but I'd have to get the shifters from eBay and wait longer for them to come in.
    Oct 2011
    Shimano Deore M596 are incredible brakes, you won't be sorry. For the drivetrain I'd go with X3 shifters/X3 rear d. or Acera/Acera. There is no need for Deore/X5 rear d. if you're on a budget. Also 7 speeds are enough for basically everything.
    May 2013
    Thanks.
    Reputation: Aresab's Avatar
    I agree with the M596 brakes, they are great. On the rear derailleur, another option is the Deore M592 Shadow or M662 SLX. Both work fine with 7-9 speed, have a fixed b-pivot like SRAM, bounce around less than the Acera - Deore M591 (any Shimano with a spring loaded b-pivot). On my 8/9 speeds, I find the M592 great. Here is a link if your interested:
    Shimano Deore M592 SGS Shadow Derailleur > Components > Drivetrain > Rear Derailleurs | Jenson USA Online Bike Shop
    If you spend 1 more cent, it will ship for free.
  1. Ancient Altus brake lever question
    By fgiraffe in forum Brake Time
    Last Post: 09-16-2017, 03:12 PM
  2. Changing stock Altus 7 speed RD to Deore on a Hardrock 2011
    By funkyworm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 01:36 PM
  3. Altus, Oklahoma
    By jfraser73 in forum Great Plains - OK, KS, NE, SD, ND
    Last Post: 09-11-2012, 05:51 AM
  4. Altus shifter compatibilty with Tourney RD
    By Basser in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2012, 10:38 AM
  5. what happend to acera and altus ?
    By nailtrail in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2011, 10:37 PM
