    Need new bearings and cap for my RF Deus crankset
    I smashed the black cap (the thing Hecubus is holdning in his hand - hope it is okay I use the picture). The bearings in the right side also seem quite worn out. Does anyone know where I can buy these new parts?
    And does anyone know if XT bearings are compatible with the Deus crankset?
    Any info is highly appreciated
    /Anders
    Quote Originally Posted by Danish Dynamite
    ...And does anyone know if XT bearings are compatible with the Deus crankset?...
    They are, in fact they use the same size sealed bearing #6805. How did you crack the bearing cover?
    Quote Originally Posted by Ratt
    Thanks for your answer. I think it either cracked when my friend who is a bike mechanic tried to pull it out or then it cracked because I had tightened the bolt too hard. I have had a lot of problem with the crankset and I will buy some new bottom bracket cups. Hopefully that will solve the problems.
    Does anyone know if the cap comes with the bottom bracket cups?
    Reputation: skywaybuzz's Avatar
    Yes they do. The XT should be quite good.
