Results 1 to 3 of 3
    need help w/ SRAM small parts
    I cracked the shifter gear indicator on the right hand side (rear shifter). I imagine a few has done so. It's a 9-speed SRAM Rocket shifter - same size as Attack. It's a slight cosmetic issue but an eyesore for me. The part # is 00 0000 200 528. The sram website has no customer service email add (unless I'm blind) and the LBS ain't lucky either. Any help will be appreciated.....
    Nov 2008
    Sram offers the LBS a phone number linking them to tech support. Any shop can call and probably get you the part with very little effort. If yours won't make the call try another one.
    I'd give you the number, but Sram prefers to deal through the LBS.
    BTW- if no local shop will help, email me (use mtbr's email link) & I'll call Sram on your behalf.
    fb
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    I'd appreciate it. Check your pm....
