    Dec 2012
    Need help repositioning small chainring - Shimano XT FC-M785 2x10 26/38
    I had a piece of tape on the small chainring telling me where to put it in relation to the crank arm, but it came off...should have used a marker
    can someone tell me how to put it back?
    on the large ring, there is a number 1 nearby...the small ring also has a number 1...do these line up?
    Fat-tired Roadie
    Nov 2007
    I found a picture online and it shows a little tab projecting inward between two of the bolts.
    That lines up with the crank arm.
    Mar 2011
    Re: Need help repositioning small chainring - Shimano XT FC-M785 2x10 26/38
    What he said. All the rings have a small tab on the inside. The tabs are supposed to be in the direction of the crank arm.
    Dec 2012
    thanks guys
