Results 1 to 5 of 5
    Mar 2013
    Need help removing cassette body.
    This is for a 2013 Stout SL hub that came on my Specialized Carve Sl 29 single speed. I'm in the process of changing the rear gearing and want to clean out the hub while i'm at it.
    I have no idea how to remove the end caps, cassttee body and axle. Has anyone done this before? Each end cap is held on by a screw. Name:  IMAG1331.jpg
Size:  33.1 KBName:  IMAG1332.jpg
    May 2015
    Did you have any success? I have the same bike and wheels and am trying to replace the freehub. I have removed the endcaps after loosening the small recessed screws, but am having problems removing the axle. How did you remove the axle?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Quote Originally Posted by Richard SD View Post
    Did you have any success? I have the same bike and wheels and am trying to replace the freehub. I have removed the endcaps after loosening the small recessed screws, but am having problems removing the axel. How did you remove the axel?
    There is no axle inside that hub. The removeable end caps only provide a sleeved flange to thread the QR "axle" through. Once the end cap setscrews are loose - simply use a pair of pliers and a rag to firmly pull the caps out.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    May 2015
    Thanks. I did pull off the caps, but I believe I need to remove the exposed shaft so that I can get an allen wrench inside to loosen the freehub, correct?
    Please take it to your LBS and see exactly how they do it. Take notes, pay them and you'll be able to do this yourself from this point forward...
  1. XX1 on a 142+ rear hub - which cassette body?
    By Green Giant in forum Specialized
    Last Post: 02-09-2013, 06:29 AM
  2. Replies: 3
    Last Post: 12-04-2011, 06:12 AM
  3. Quick ? regarding removing cassette TOOL.
    By ProjectDan35 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2011, 06:13 PM
  4. Help removing cassette
    By Devedander in forum Beginner's Corner
    Last Post: 04-28-2011, 05:40 PM
  5. Removing the guide pin from a cassette tool
    By Wombat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2011, 03:41 AM
