Results 1 to 3 of 3
    Jan 2009
    need advise on a middle ring
    hi there mtbkrs,
    I'm looking for a new middle ring for my truvativ stylo crank.
    what are the choices out there? it has a 4 bolt pattern
    thank for your advise
    T.W.O.
    Reputation: mimi1885's Avatar
    Check the BCD on the Crank, Universal cycles offer a wide range of chain rings.
    Former Bike Wrench
    Its standard 104, replacing with another Truvativ would be best unless your replacing the entire set. You can get either alloy or steel, depending on if weight or durability are your primary concerns.
