Results 1 to 8 of 8
    Bunny Hoppin Gators
    Reputation: drivengsxr1000's Avatar
    N-Gear Jump Stop Chain Guide what size clamp to order
    there is 3 clamp sizes 31 28 and 34 how can i be sure what size to order i think its a 31.8 but not sure,
    its a 2011 trek ex7
    Bunny Hoppin Gators
    specs say my seat post is a 31.6, does that mean the 31.8 will work?
    Bunny Hoppin Gators
    107 people on this forum right now someone has to know, ive been trying to figure this out for over an hour now
    Aug 2005
    Im not to familiar with the n gear.. Doesn't it mount in place of front deraileur? If so look up the clamp size for that. I believe the seatpost is measured by inside diameter of seat tube / outside diameter of seatpost....
    Yes the 31.8 clamp will fit on your Trek based on the 31.6 seat-tube diameter....but I would not use the n-gear chain stop on a full suspension bike.......I had it on a 4 inch travel Giant NRS with the same 4-bar suspension as the Trek and the chain would fall off during maximum compression of the shock (the chain would move up past the chain-stop so it would fall over it and then to the inside.
    I imagine it will be worse on the 5-in travel EX 7...the plate on the n-gear is just on tall enough to account for the amount of vertical travel that your chain goes through as the shock cycles through its travel.
    The other problem I had was the clamp was made from reall flimsy plastic and it would sometimes rotate when the chain got jammed and then I had to readjust it every single ride.
    If you are thinking of going 1X or 2X I would look for a chainguide from E13 or MRP or similar...
    Bunny Hoppin Gators
    i think i will go with the high seat tube mount chainguide from mrp
    Reputation: Nater's Avatar
    Quote Originally Posted by osmarandsara View Post
    This isn't true...that would mean the the seat tube walls are only 0.1mm thick.
    Generally speaking, a bike that uses a 31.6mm seat post will have a 34.9 outside diameter.
    ^^ Correct.
    You need the OD. I found this out the hard way. Doh.
    If you goto N-Gear's site, there are instructions on how to measure.
  1. N-gear jump start chain guide
    By james_hetfield in forum General Discussion
    Last Post: 06-04-2010, 08:16 PM
  2. What size N-Gear Jump stop?
    By butler524 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-01-2009, 09:23 PM
  3. N-Gear Jump Stop Chain Guide
    By Popper252 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2009, 06:16 AM
  4. Replies: 23
    Last Post: 09-21-2007, 08:54 AM
  5. N-Gear Jump Stop and others
    By fish man in forum Singlespeed
    Last Post: 05-24-2005, 10:32 AM
