    Reputation: Vecsus's Avatar
    At my wits end...shifting problem
    The shifting problem is that if I dial in the higher (outside) gears perfectly, then the lower (inner) gears jump around the cogs. If I dial in the lower gears then the higher ones skip around. Very frustrating. I've followed the instructions on the Park Tool site and I have never had this kind of problem dialing in a bike before.
    (If it matters, I just bought a Iron Horse Hollowpoint this weekend and replaced the stock XT shifters/derailleurs with my SRAM X.9 setup from my old bike...the sram set worked fine on the old bike.)
    Any advice would be greatly appreciated.
    Sometimes...
    and this probably isn't your problem, the cables get grunged up and the spring on the derailleur isn't strong enough to overcome the friction. Pull your cables, clean, lube and look for a kink also.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    First, I'm assuming that the RD limit screws & indexing has been properly adjusted and that the drive train is new.
    Try to get yourself a Park DAG-1 RD alignment tool & make sure the RD hanger is properly aligned. I've been surprised at how many hangers are misaligned, even when new, and have found it to be a common cause of mis-shifts.
    Well the problem is fixed now. I had pulled the wheel, cassette, chain, RD and shifters off my old Dakar. Moved the entire driveline over to my new Iron Horse Hollowpoint. Everything worked fine on the dakar but caused problems on the Hollowpoint. Finally I ended up throwing the new cassette and chain on the bike and it worked fine. The chains were both the exact same length so that was not the issue. I guess the new bike just didn't like those old parts. I guess that would be like asking a new wife to wear your ex-wifes clothes...not a good way to get her driveline tuned in
    But I appreciate the replies. My next option was to have the hanger checked out.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. shifting problem?
    By d3vil in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2004, 01:56 PM
  3. Ghost shifting on a new 575
    By drakh in forum Yeti
    Last Post: 05-13-2004, 07:20 AM
  4. I'm at my wits end - Creaking
    By BBOC in forum General Discussion
    Last Post: 04-27-2004, 03:22 PM
  5. Sugar 3+ Drive Train problem / question HELP!
    By mattstep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 01:42 PM
