Results 1 to 13 of 13
    Smile Is my Chain Lenght too short?
    Is my chain too short?
    Since I never ever use my largest chainring on road and trails, I decided to shorten my chain for 2x8 instead of 3x8.
    please note that I will often use big-big 32-32 on quick climb, should I put an extra link or leave it as is?
    1st pict: big-big(32-32)
    2nd pic: big-small(32-11)
    3rd pic: small-big(22-32)
    4th pic: small-small(22-11)
    nvphatty
    Guest
    the 1st pic (32-32 cross chain)bothers me but the rest are ok looks wise however do they function properly is the main question?
    Quote Originally Posted by nvphatty View Post
    they function but I havn't test it out with any force yet as I worry its too tight for 32-32
    Looks spot on to me.
    Reputation: lew242's Avatar
    Looks like mine all though I use SRAM X7 short cage. In fact my derailleur is more stretched out, one chain link shorter or more than the top picture. I started measuring my own chains years ago after relying on lazy shops that left my chains too long and ended up damaging my drive trains and getting too much chain suck.
    If that's big big in the first picture, it's fine. Might even be able to go one link shorter
    nvphatty
    Guest
    Quote Originally Posted by Slash5 View Post
    its not fine as it is and most deffinately no shorter however big/big is seldom used.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    it's fine... about the only issue I see is the upper jockey seems a bit far off the cassette in that first pic. Could just be the pic but, General rule is the upper jockey should be around 6mm off the cassette's largest ring... tooth to tooth... move it in by turning the "b" screw... it's the one in the back...
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    nvphatty
    Guest
    the upper wheel is plenty close to the lrg cluster ring.
    Oct 2007
    from shimano's manual.... they want it almost touching.. thou after both areas of test it'll end up right around the 6mm mark depending on hanger spotting on the cassette....
    nvphatty
    Guest
    my trail manual superceeds shimanos so i'll win!!!
    Oct 2007
    ok,.. Lolol
    Plays with tools
    Reputation: customfab's Avatar
    I'd like to see another link in there, but not bad enough to break the chain. When it comes time to replace the chain, add a link.
  1. Chain stay lenght of 2014 Epic and Stumpy FSR
    By Pex in forum Specialized
    Last Post: 04-20-2013, 04:15 AM
  2. chain lenght on 5.7 carbon
    By lecoz in forum Pivot Cycles
    Last Post: 03-15-2013, 07:50 AM
  3. Is this chain to short?
    By machine4321 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2012, 04:06 PM
  4. Chain lenght on Ogre
    By Ze_Zaskar in forum Surly
    Last Post: 07-10-2012, 11:40 AM
  5. Chain lenght question
    By AMCAT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2011, 11:28 AM
