Results 1 to 1 of 1
    May 2005
    Mrp Bones Installation
    Wanted to see what info I could get about this.
    Just got a pair of the MRP Bones Cranks (used) and I think I might have a problem with the non drive side. If you look at "WasherSetUp.jpg", this was how it was set up on the previous bike. Pretty sure it was a 73mm BB width. My bike has a 73mm width. Trying to install it with this set up, the non-drive side cup stuck out quite a bit (at least 1/4"). So I moved one of the spacers to the outside of the cup (spacer circle in red) and see "NonDriveSide.jpg".
    Is it a good idea to do this? Since the cups have cartridge bearings, will the pressure
    from this spacer damage the bearings? Or does the crank-arm need to be flush to the cup? Also, once everything is tightened, there is very little back-spin from the cranks. A good push will spin it maybe one time around. And I'm not tightening that much. Would this be normal and would it loosen up a little once I rode it for a bit?
    Any help would be great!
  1. MRP Bones LRP System 2 Report
    By misctwo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2005, 12:38 AM
  2. Mrp bones
    By madmax in forum Downhill - Freeride
    Last Post: 10-10-2004, 06:59 PM
  3. ? ? ? Anybody Run MRP Bones ? ? ?
    By trp_patrick in forum Downhill - Freeride
    Last Post: 05-28-2004, 04:27 PM
  4. MountainSpeed MRP Bones Combo cranks?
    By GiantAC1 in forum Downhill - Freeride
    Last Post: 05-09-2004, 03:05 AM
