Thread: MRP 1.X washers
    MRP 1.X washers
    What are the 4 washers for that come with an MRP 1.X? I assumed they were spacers for your chainring bolts but the diameter is way too big.
    JayMac
    They are spacers for fine tuning the chain line of your chain guide I believe.
    I dealt with the MRP 1x for awhile. Those washers should be used to adjust the positioning of the guide about your chain, but the bolts used to attach the actual guide to the frame mount are too short to use even one of those plastic washers. Ultimately, the 1x guide is GARBAGE. The cage is way too narrow for a 1x10 setup, and there is only 1 axis of adjustment on the entire guide.
    In short, either get a Paul Components keeper, or get a clutch-type RD, a Wolf Tooth Drop Stop chainring, and go keeper-less. I loathed that guide. Hope something works for you!
    I've got it installed and don't have any issues so far. I actually had to remove the 2 pre-installed spacers for a good chain line. My LBS told me to get it straight in the 5th cog as a starting point. The chain sometimes does rub in the big 36 cog, but I have full range of all 10 of them.
    https://www.facebook.com/photo.php?f...type=3&theater
  1. Crush Washers--Fox
    By steadite in forum Shocks and Suspension
    Last Post: 01-04-2013, 06:49 PM
  2. crush washers
    By Inuitbiker in forum Where are the Best Deals?
    Last Post: 05-10-2012, 01:20 AM
  3. Ti bolts... do I need washers??
    By mgv101 in forum Weight Weenies
    Last Post: 04-16-2012, 08:54 AM
  4. Do you have washers behind your rotor?
    By monkei in forum California - Norcal
    Last Post: 05-17-2011, 03:16 PM
  5. big spoke washers
    By customfab in forum Wheels and Tires
    Last Post: 03-11-2011, 05:06 PM
