    Flying Goat
    Reputation: mrpercussive's Avatar
    More BB Questions
    If i'm using a 73X113 Isis cranks... can i use Truvativ Howitzer BB??? Whats the equivalent of the spindle lengths???
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    If you are running 135mm rear wheel (aka Quick Release), which you likely are with a 113 spindle, then get the 68/73mm version for 50mm chainline.
    http://www.universalcycles.com/shopp...2&category=346
    This version: 9462-20350 68/73mm x 50mm
    Flying Goat
    Quote Originally Posted by oldskoolbiker
    thanx for clearing that up... so how far the spindles are from one length t the other from 113mm to the 50mm on the Howitzers should be the same?
    Flying Goat
    what if it's a 51mm chainline??? I think in 2006 thats what they were made in... not 50mm... will it work? What are potential problems?
