    Morati Titanium cranks. difference between mtb and road cranks?
    Is there any difference between MTB and road bike Morati ti cranks? Or is it one set suites all?
    If there is two types how can you tell the difference?
    Josh
    ups and downs
    Bolt circle and the number of rings they mount. Road cranks typically use a larger bolt circles and often will only mount two rings on one big bolt circle.
    Ok. Kool these look to bolt three chainrings. i will post a pic and let me know if they are road or mtb.
    Josh
    ups and downs
    That looks like a small BC, but you'd want to measure them to be sure. A 5 bolt MTB crank will either be 74/110mm standard or 58/94mm compact.
