Results 1 to 9 of 9
    Middleburn crankset
    Thinking about going 2x9 with a 44 and 32, 30, etc chain ring combo. It looks like a Middleburn is a decent option, and can be purchased for under $300.
    The only concern here is the bottom brackets required are either an Isis or square taper. Are these good options compared to a bb30 FSA Afterbuner? Is bb30 or bottom bracket selection more important than gear options and weight on a crankset?
    Former Bike Wrench
    Middleburn has X-Type crankarms which most closely compare to BB30.
    http://www.chainreactioncycles.com/M...?ModelID=55466
    BB30 requires a frame that has a BB30 Bottom bracket shell, which most frames currently don't have.
    Rider and Wrench
    Reputation: knottshore's Avatar
    A bit off topic but...
    Why do the X type RS8's not look as lean and machined as the ISIS & Square RS8 and RS7 Cranks? I was happy that they finally came around but they are a bit blah compared to my current ISIS RS7's
    The first two are the ISIS / Square the second two are X type-
    I Just wish I could ride more!
    Tá mé ar meisce.
    Reputation: BeerCan's Avatar
    I agree the older style looks better. I kind of like the more "square" look.
    Does anyone know if they plan on making the x-type in 180mm?
    To see what is right, and not to do it, is want of courage or of principle. -- Confucius
    Come join me at the Swamp
    Middleburn & bb30
    Thanks for the information. Say, I have one more question.
    My frame is bb30 compatible, but I have a GXP bottom bracket installed with an adaptor to fit a bb30 frame. Using the cranks shown in CRC link, would I need a new bottom bracket like a bb30?
    Take care
    Rider and Wrench
    Quote Originally Posted by 26hardtail
    Take care
    This is directly from the link you referenced-
    "The X-Type version uses a floating 24mm alloy BB axle"
    You would not need any adapter it would fit right into the GXP BB you have- as sram/truvativ uses the 24mm format-
    Thank you
    Thanks for the input. I appreciate the help.
    Former Bike Wrench
    Quote Originally Posted by knottshore
    NO
    It is not compatible with the SRAM GXP system, it is compatible with the Shimano (or equivalent) system. They are not cross compatible. SRAM uses a stepped axle that is actually 22mm on the non-drive side.
    http://www.middleburn.co.uk/x-type-f...structions.pdf
    Rider and Wrench
    Quote Originally Posted by mtnbiker72
    NO
    My bad- I was thinking Race Face X-type not GXP -thanks for the correction mtnbiker72
    The adapter for installing it in the bb30 should still work but you will need a Shimano compatible bb - Race Face, FSA, Etc...
