Results 1 to 2 of 2
    On your left.
    Is this a MegaQuad or regular Platinum pro Ti BB?
    shop and FSA say it is a MegaQuad because part number (200-1075) on box is correct.
    I say no way - this must be an standard 2004 platinum pro ti BB. It doesn't look like the megaquad on the FSA website and the non dirve side bearing is about 7mm wide (sorry for the wierd units on the ruler - I had it rotated wrong). FSA says the megaquad should have a 14mm wide bearing. (note - don't be confused - it looks like the width according to the ruler is about 14, but that is 14/50ths of an inch which equals .28 inches, or 7.1mm).
    Anyway I'm having a hell of a time getting a megaquad BB.
    By the way, weight of pictured BB is 195g, aluminum crank bolts and steel washers add 21g.
    M
    Reputation: Jeff K.'s Avatar
    That's the regular Platinum Pro with the two bearings on the driveside and one bearing on the non-drive side. Just pulled the same bb out of a frame this morning.
  1. FSA Platinum Pro Ti MegaQuad
    By Motivated in forum Weight Weenies
    Last Post: 03-01-2005, 07:26 PM
  2. FSA ISIS Platinum Pro TI bearings
    By WOY in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2005, 08:53 AM
  3. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  4. Replies: 0
    Last Post: 04-08-2004, 08:40 AM
  5. 2004 FSA ISIS Platinum Pro II BB Reliability?
    By bortiz24 in forum General Discussion
    Last Post: 03-31-2004, 12:38 PM
