Results 1 to 24 of 24
    May 2010
    Idea! Matchmaker for Avid Elixir/Juicy & Shimano shifters w/pic
    Hi guys,
    I've received my Hope matchmakers today ...
    Results : It works
    The Set up
    Brakes : Avid Elixir CR
    Shifters : Shimano XT 2011 (10sp 770 10sp)
    Matchmaker : Hope Tech Shimano XT (also works for XT 08-10, SLX 09-11, Saint 09-11)
    Cons :
    • The raw finish is not that great when everything else's black on the handlebar
    • The shifter indicator should be removed due to the lack of space between the brake lever and the shifter. It's not that bad, it save some weight and you just have to place a cover instead of the indicator, wich is just behind the indicator.
    Here are some pictures (click on the pictures for higher resolution) :
    meow meow
    Reputation: b-kul's Avatar
    thats pretty sick. how much did it cost?
    May 2010
    $38 shipping included with CRC. I lived in Europe that's why the shipping is free but it's around 8 or 9 bucks of shipping from America . I know it's not cheap but it works and I was looking for such a thing for months .
    I forgot to do the weight (of the Hope Tech Matchmaker) when I open the box but in my hand it was lighter than the shimano clamp.
    It save 79 grammes :
    By removing :
    • XT Indicators (around 23 grammes)
    • Avid Elixir clamp (9 grammes)
    • Shimano XT clamp (around 47 grammes)
    Mar 2006
    I just ordered a set for SRAM XO shifters and Hope Tech brakes from AE Bike. I think they were $35 with free shipping (orders over $75). Will post pictures when they arrive next week.
    May 2010
    If you have a pair of Elixir or Juicy you don't need to buy Hope Matchmaker clamp. You already have this avid matchmaker. But if you got a pair of Hope Tech brakes you did the right thing .
    The main idea with this topic was about mixing avid brakes and shimano shifters with an "officially not compatible" matchmaker, the Hope "tech" matchmaker in our case.
    Reputation: cant fix a flat's Avatar
    will the avid matchmaters work with shimano shifters?
    May 2010
    Quote Originally Posted by cant fix a flat View Post
    No, that's why I've written this post
    Reputation: jeate's Avatar
    shimano i-spec 2012
    anyone know if this would work with new shimano i-spec 2012?
    Feb 2010
    Will this work for XX brakes with XO shifters? Anyone know? Where do you even find these things? On Hope's website?!
    Thanks for the help!
    Reputation: HighLife420's Avatar
    Quote Originally Posted by HeadFirst! View Post
    You need a different clamp, not the hope....you can match Avid brakes and Sram shifters np. This is what you need.
    Since the OP is using Shimano shifters, he used the Hope clamp since they dont make one for shimano.
    Oct 2011
    xtr m985 brakes n xo shifters
    just ordered m985 brakes and am currently running xo shifter. is there a clamp that will mount them together like my matchmakers or do i need to get clamps to mount the shifters seperate and i cant find mounts for my xo shifters.
    Reputation: purdyboy's Avatar
    This is something I was thinking about, glad there is a product for it.
    Does anyone know if there is a similar combined mounting for matching the 2012 XT shifter (SL-M780) and new 2012 Avid Elixir 9 brakes?
    Thanks for any helpful info.
    BTW I found this clamp/adapter, might be of interest to some:
    Trickstuff
    Ride Safe.
    www.lighttouchchiropractic.com.au Manly Sydney
    May 2010
    Not really sure if there is a product to go with if you want to solve the problem of XT 2012 shifters and 2011 and 2012 Elixir.
    Sadly the Hope matchmaker cannot fit the Elixir's since 2011, but thanks to you purdyboy, I'll send an email to Trickstuff.
    Reputation: Sevenz's Avatar
    Anybody know if the Hope matchmaker will fit the Magura MT line of brakes...Would like to use it to Match the Magura MT6 to an XTR 10 speed shifter...If that is not possible anyone else have any other suggestions?
    The Hutch
    Reputation: rob1208lv's Avatar
    Quote Originally Posted by chrisscrubz View Post
    +1 I also would like to know. I'm currently matched with adid brakes and xo shifter, but I hate the brakes and want some Shimano xtr is there a match maker for this set up..??
    follow me
    on FB @hutchsbicyclegarage
    on instagram @hutchsbicyclegarage
    and @robbhutch
    on twitter
    @RobertEHutch
    Hallo guys.
    My first post Did anybody make a matchmaker clamp for the new avid elixir 9 brakes and shimano xt triggers?
    Jun 2010
    MerlinCycles has these clamps in black now. I just got a set for $29.55
    May 2010
    Hey Mitch is it also available in black for XT shifters, the hope tech matchmaker, or is it the black one only for XTR ?
    Plays with tools
    Reputation: customfab's Avatar
    Those are pretty slick. Now if only Avid would make a decent brake...
    Jun 2010
    Quote Originally Posted by customfab View Post
    They do, they are called code 5,just my opinion
    Jun 2010
    Quote Originally Posted by euskafreez View Post
    Hope Direct Shifter Mounts - Tech Lever | Hope Disc Brake Spares | Merlin Cycles
    Looks like they are out of stock
    May 2012
    I wonder if something like this would help me adjust my SRAM X4 shifters so the work better
    May 2010
    Quote Originally Posted by MitchD View Post
    Yep they are out of stock at the moment but at least I know are also available in black. I already have them in silver so I'm not in a hurry.
    Quote Originally Posted by deanopper View Post
    Not necessarily, for some the shifter ergonomics is better, for some it's worst. I belong to the first category, both shifters and brake levers handling have improved, it looks cleaner and it saves some weight.
    But you can't mix that easily shimano shifters with avid brakes anymore, if you have 2010 or older avid brakes then it's ok, otherwise :mad.
    Any update?
  1. Replies: 0
    Last Post: 04-16-2011, 04:47 PM
  2. Avid elixir 3 vs juicy 3
    By HX520W in forum Brake Time
    Last Post: 03-05-2011, 04:16 PM
  3. Replies: 4
    Last Post: 03-31-2010, 04:33 PM
  4. Avid Juicy 5's vs Elixir CR vs Hayes vs....
    By Paul_G in forum Brake Time
    Last Post: 11-01-2009, 08:06 AM
  5. Same issue with Avid Elixir CR and Juicy 5's?
    By Evo. in forum Brake Time
    Last Post: 09-16-2009, 12:28 PM
