Results 1 to 8 of 8
    Apr 2005
    Make my Giant Rincon shift better
    I want to upgrade my derailers. Which derailers can I put on my Giant Rincon without having to change anything else (i.e. shifters and gears). Here is the link to my stock bike... http://www.giant-bicycles.com/us/030...sp?model=11040 . By the way I am 6'6" and 285 lbs. If that makes a difference to what I should get. Thanks for the help.
    ballbuster
    Reputation: pimpbot's Avatar
    What's wrong now?
    Quote Originally Posted by infinityarms
    When you say your bike is not shifting well, specifically what is wrong? Does it hunt before going to the next gear? Does it chain suck?
    It is equipped with Acera derailleurs. While certainly not bling parts, as long as everything is straight and adjusted, it should be fine. I rock Acera derailleurs and shifters on my 5 year old Giant Yukon I use for commuting, and the shifting is as crispy as can be.
    Apr 2005
    Quote Originally Posted by pimpbot
    It won't hold an adjustment, on either end. It also feels like it jams into gears on the rear derailer. The front derailer must have a six mile notification system built into it. Because it won't go into my smallest chainring.
    Apr 2005
    It has front derailleur Shimano Acera and Rear derailleur Shimano Alivio.
    Do these derailers need to be tuned more frequently that the higher line? If so, what level do I need to go to in order to avoid contant tuning?
    ballbuster
    No, not really
    They should not need more tweaking than higher end stuff. The higher end stuff is a bit crispier to shift and weighs less... that's about it. As long as you are not buying department store crappy bikes, the derailleurs should be decent.
    It sounds like they are just out of adjustment, or you have a bent rear derailleur hangar. Check the pivots for slop. If the pivots are excessively sloppy, the replace the derailleurs.
    Keep in mind that all derailleurs slam when shifting if you don't let up on the pedals. Also, the front will not go to granny if you are pedaling hard. The tension on the chain will be too much for the spring to overcome. This is true of all derailleurs.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Listen to Pimpbot. He is correct. The parts you have should shift fine.
    I just replaced my Acera rear derailleur last year on a 1996 model bike, the front is still on it. Probably didn't need it, but did it just to update everything. Replaced it with another Acera. If things are bent, that is a different story, but Acera stuff will shift fine when adjusted properly and I have a hard time believing you could actually wear it out that fast.
    You should also inspect your shift cables for problems. How you carry or store the bike could also be a problem if the cables are pulled or stretched while transporting or while stored or somehow binding.
    Put the bike on second gear and get down low behind the rear wheel and see if the top gear pully on the rear derailleur is DIRECTLY in line with the second largest gear on the cassette. If it is not, the best thing to do would be for you to download the directions for adjustment from Shimano and follow them closely.
    If you are just wanting to upgrade for the heck of it, look on e-bay for some older XT 8 speed shifters. They work very nicely and you might find a good deal on them. Problem with upgrading shifters on a bike like yours is that most have the brake levers integrated into the shifters and that means you'll have to get new brake levers too. If you do upgrade, look for separates so this won't happen again.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    If you're having "adjustment" problems ...
    I recommend that you replace your shifters/derailleur with SRAM. X.7 can be had for $70 for shifters and derailleur.
    SRAM stuff needs less "tinkering" to stay in tune. It's also more immune from cable gunk.
    Live 2 Ride
    Reputation: Kona0197's Avatar
    Stick with Shimano. Unlike SRAM the Shimano stuff dosen't break as often. By the way there is nothing wrong with running low end parts. Sometimes they out-perform the high end offerings.
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
  1. Giant Warranty Policy
    By Ray_from_SA in forum Giant
    Last Post: 04-02-2005, 03:40 PM
  2. How to make my giant warp good?
    By puttsey in forum Downhill - Freeride
    Last Post: 03-22-2005, 07:23 AM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. 3D-Link vs Giant NRS
    By macming in forum Shocks and Suspension
    Last Post: 10-31-2004, 03:30 PM
  5. $300-$350 Budget. Trek 4300? Giant Rincon?
    By nobrainer372 in forum Bike and Frame discussion
    Last Post: 09-30-2004, 09:14 AM
