Results 1 to 9 of 9
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    LX vs XT derailleurs
    For sake of clarification, I've already tried a search, but it tells me no matches found, so I have to believe that yet again, the search engine is down.
    I'm doing a budget build for a hardtail bike and I'm trying to get a difinitive answer regarding the true difference in performance between the more current LX and XT offerings. My sense of things is that the LX should perform well enough for the build and that because LX seems to be Shimano's "red-headed stepchild" that I will be able to get a much better price on LX derailleurs than XT. I'm watching no reserve auctions for LX rear derailleurs go for as low as about $15 for LX, whereas the XT stuff is more around the $35-$45. In my mind I can't justify the cost difference, especailly if the technology on the LX gear is truly trickled down from some of the past XT technology.
    Help me put this in perspective. (Hecubus?? You out there??)
    Thanks,
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    At 15bucks how can you go wrong? Although, I'm far partial to SRAM for this part -- IMO the extra scratch is worth it here...
    Am I helpful, no.
    Is this post useless, prolly
    as you were...
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Call_me_Clyde
    Thanks,
    Bob
    I had a LX RD... but have never had a XT.
    However, the thing shifts smoothly (actually, the Deore already does that too), never misses a shift and it took with ease the 8 months of use I gave to it. I sold the bike off... so maybe it exploded into million pieces or maybe it's still going strong.
    LX took a bad rap a few years ago. Also, was kind of a pointless gruppo as it was closer in price to the XT, but closer in performance to Deore. So the gain was little if you took the LX route.
    This was before the 580 series... the newer 580 is one of the best values in Shimano... HTII cranks, Dual Control (whatever that means to you) and is very strong.
    I would go for the LX and maybe upgrade in the future to the XT... but I'm positive you'll not miss anything.
    Check my Site
    Reputation: matej_m's Avatar
    My first post here..
    I had a bike with XT RD, Deore FD and Deore shifter levers, now I have Deore RD, Alivio FD and Alivio shifter levers. I can feel the difference, but that is because of levers.
    I belive there is no big difference between LX and XT, you can't go wrong with LX!
    Matej
    Chrome Toaster
    Reputation: Hecubus's Avatar
    There will be very little difference in performance from LX to XT and even LX to XTR really. The biggest difference is the construction. LX has more material on it than XT so its a bit heavier. The cage on the LX is also a sort of universal one size fits all. Its REALLY long long cage, only one model. Longer than XT long cage. Or at least it used to be, I haven't really verified on the 580 series. I'm not really sure about this but I believe the pulleys might both be bushing instead of bearing. If you're looking for a budget build you really can't go wrong with one of those ebay LX ones. I picked up a brand new on for 9.99 once
    Freshly Fujified
    LX it is
    Thanks everyone. I do appreciate the input. As always I look for bang for the buck and get the sense that the LX will perform well, yet still keep me well within the budget I have established.
    Bob
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Hecubus, both pulleys are bushing, and the cage is flippin' huge. You are correct.
    Reputation: yedithefireman's Avatar
    get the LX and save the money, you wont feel a difference between the two
    Freshly Fujified
    Partial to SRAM, too
    Quote Originally Posted by Jwind
    Am I helpful, no.
    as you were...
    I also happen to be partial to SRAM. I rin X.7 on my full suspension rig. Problem with SRAM X series components is that they tend to carry the same premium that the Shimano XT gear carries. I'm not familiar enough with the SRAM SX series to be comfortable in using it. I have used LX and XT in the past so given my circumstance (I want good quality, but cheap!) I'm going with LX.
    Not useless at all. Thanks for the reply.
    Bob
