Results 1 to 6 of 6
    Jun 2010
    Losing engagement periodically on smallest cog
    Let's see if I can explain this correctly:
    Hammerschmidt up front, XTR components in the rear. All new (less than 50 miles on everything, including chain & cassette)
    This only happens when on the smallest rear cog, but there it is consistent.
    When on that cog, in either gear on the front, it's engaged fine for one or two rotations, then seems to disengage, slip a link or two and then reengage for the next couple turns of the crank and repeats again and again.
    Any ideas?
    Two Wheel Offroad
    Reputation: T_W_O's Avatar
    Check your hub, it may need rebuild.
    Jun 2010
    I'll look into it, but I feel like if it were the hub, it would do it regardless of where on the cassette it is. I think, while I'm there, I'm gonna check if I can see the chain jump off the cog as well.
    Two Wheel Offroad
    It happened to me on the Mavic Xmax Sl it was really annoying, later I found out I had to replace a bushing.
    Fat-tired Roadie
    Nov 2007
    Stiff chain link, dirt packed into the cassette.
    wipperman link upside-down?
    tight pin in chain?
    gonna be something like that for sure!
  1. Do i need to periodically add Float Fluid
    By Gromit_dog in forum Trek
    Last Post: 06-20-2011, 12:56 PM
  2. Losing 1 lb off body VS Losing 1 lb off frame
    By rydbyk in forum XC Racing and Training
    Last Post: 04-27-2010, 08:13 AM
  3. Rear shifting problem, goes from 3rd smallest to smallest cog, skips 2nd smallest
    By Mike E in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2009, 03:20 PM
  4. Do Helmets Need Replacing Periodically??
    By cohenfive in forum Apparel and Protection
    Last Post: 03-21-2008, 10:31 AM
  5. Replies: 20
    Last Post: 01-14-2005, 10:11 AM
