Results 1 to 12 of 12
    Aug 2015
    looking for better cassette for climbimg
    so here is my little story not a very good climber. I ride a 2015 rocky mountain altitude 750 all stock.
    I am looking to et a better ratio for climbing
    was looking at a oneup 42t. wondering if I can kee my crank on it now?
    Fat-tired Roadie
    Nov 2007
    What's your existing drivetrain?
    Sent from my E5803 using Tapatalk
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by dodgeboy8888 View Post
    Go to the Drivetrain forum. And when you ask, write out in detail what drivetrain components are installed on your bike. That will take less time than for each potential responder to go look up your bike's components.
    Oct 2015
    I owned that exact bike. You should have a 2x10 setup with a 11-36t cassette. I suggest an 11-42t cassette and a goat link. The Sunrace 11-42t and goat link can be found readily in good bike shops and online.
    Oct 2015
    Then when you grow some legs ditch the front derailleur and go a single ring.
    Apr 2016
    Quote Originally Posted by GRPABT1 View Post
    Or just keep the current set of legs and get a 28 ring in the front!
    Aug 2015
    if i was to go 28t front and 42t rear . would be better then 22t front and 36t rear
    Fat-tired Roadie
    Nov 2007
    Nope. It would be a higher gear. But 26/42 or 28/46 would be pretty comparable. Gear ratios are literally ratios, so if you're not changing wheel size, you can just do the division to compare different options.
    Aug 2015
    so 42/28=1.5
    and 36/22=1.64
    so 36/22 is an easier ratio
    Fat-tired Roadie
    Nov 2007
    Usually people divide the chainring teeth by the cog teeth. So a lower number corresponds to a lower gear.
    m66
    m66 is offline
    Jul 2014
    Well, you can calculate any way you like, 22/36 is still easier ratio then 28/42
    Sent from my Nexus 6P using Tapatalk
    Magically Delicious
    Reputation: Cleared2land's Avatar
    This is my advice...grow some legs and the gearing and ratios will come easy.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Shimano cassette a bit loose on rear cassette hub
    By anymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 2 Weeks Ago, 07:16 AM
  2. Recon 11-40 cassette vs praxis 11-40 cassette weights
    By fxrextreme in forum Weight Weenies
    Last Post: 09-23-2016, 10:40 AM
  3. Cassette Rattle - Cassette or Hub Issue? (Video)
    By Tiller15 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2016, 01:02 PM
  4. New Hope Pro 2 Evo SS cassette body + shimano cassette = play?
    By marlonpants in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-26-2014, 02:59 AM
  5. cassette/freehub friction when I spin cassette
    By Gabe3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-23-2014, 08:15 PM
